4020 Gauges
Phil
03-20-2001 12:26:02
Neither the temperature gauge or the fuel gage on my 65 4020D work. How do I find out whether it is a bad gauge or a bad sending unit. I don't want to buy the wrong one. Thanks.
david val
03-20-2001 20:50:45
 Re: 4020 Gauges in reply to Phil, 03-20-2001 12:26:02
the temp gauge is mechanical,there is a bulb at the engine head and a tube(not wire!) between bulb and gauge. it shuld be replaced as a unit.
to check the fuel gauge first turn on the ignition, remove the lead from the sending unit and earth it. if the gauge jumps to the other end then you have a problem with the sender, otherwise the problem is with the gauge or wiring.
david
Phil
03-21-2001 06:42:24
 Re: Re: 4020 Gauges in reply to david val, 03-20-2001 20:50:45
Thanks. I look at them this weekend.
