JD 60 Parts # Rings Insert bearing
Ben.So.Tex
03-19-2001 16:06:23
Our local jd dealer is having problems finding part # for my 60.The pistons are stamped .090 I need the jd Part # for the rings that will fit this piston. The insert bearing have the # 1910SB stamped on the back of them, I need the jd part #. E mail me are post a reply. Thank you.
Mike Aylward
03-20-2001 04:37:16
 Re: JD 60 Parts # Rings Insert bearing in reply to Ben.So.Tex, 03-19-2001 16:06:23
Ben, the reason your dealer can't find the rings you need is because you have aftermarket pistons in your tractor. John Deere only provided one size overbore for these tractors (.045"). Odds are yours are probably aluminum, too. Rings are readily available from many aftermarket sources. As far as the inserts go, undersize bearings will be marked as to what size undersize they are. (They also are all usually marked with a date code- handy to get a general idea of when the engine was "worked over", if at all.) If yours are not marked, they are standard. They should still be available through Deere. Hope this helps. Mike
