JD 2020
Good buy?
GSS
03-19-2001 07:59:03
I am looking for a medium duty tractor and came across a 2020 Gas this weekend. It has been entirely repainted, has a JD 48 loader, 3 pt, diff lock, PS, and 4 hydraul outlets. It needs a new seat and the front and rear tires are probably less than 50%.
I am however concerned about a few things: The loader shutters and shakes the higher it goes. Steering turns farther left than right. And most of all, when the PTO is engaged, it doesn't stop with the clutch all the way in.
I think the loader shutter is due to low hyd fluid. Not sure about the steering. Did all of these have LIVE PTO, if not, that could definitelyt be why it doesn't stop!
Sorry for the book.
Thanks!
- Gerald
cannonball
03-19-2001 17:26:38
 Re: JD 2020 - Good buy? in reply to GSS, 03-19-2001 07:59:03
the 2020 has 2 stage clutch...clutch might be out of adjustment...the loader shaking going up is probably due to a few different ..low fluid ..screen or fliter stopped up...and the main thing is did they put the return from loader back into filter cover...the front pump pumps between 11 to 13 gals per min and the trans pump pumps about 7 gals per min..so once you use up what is in the reservor then is has to be made up from the trans pump...by putting the return back into the filter cover you are putting the fluid back for use to the front pump..you are looking at 54 hp...we have one that is diesel...has been good tractor...added power steering..was a very smart move... any more questions just pm me,,,, have nice day
mike
03-19-2001 13:13:18
Good buy? How Much????
GSS
03-20-2001 06:14:11
 Re: Re: JD 2020 - Good buy? in reply to mike, 03-19-2001 13:13:18
Whoops. I knew I forgot something. $6900.
mike
03-20-2001 17:06:49
 Re: Re: Re: JD 2020 - Good buy? in reply to GSS, 03-20-2001 06:14:11
That seems like a decent price.One thing i would
do on a loader tractor is raise the front end up with the loader and check front end slop.
On a lot of loader tractors the steering housing
under the front is wore out and is very expensive
to fix.A lot of the loaders shake when raising,
especially when cold.My 2550 does this to.
