What tools do I need?
Bill Oakes
03-18-2001 16:31:09
I am rebuilding my first John Deere, a model B. When I got to tearing the engine apart I realized I needed some measuring instruments to determine sizes and measure wear. I have two questions: 1. What tools have you experienced guys found to be the most useful (calipers, micrometers, etc)?? 2. Do I need to spend big money for big name manufactures or can less expensive imports do a credible job?? Your advise will be geatly appreciated. Thanks, Bill
clooney
03-18-2001 17:20:06
 Re: What tools do I need? in reply to Bill Oakes, 03-18-2001 16:31:09
Bill, the cheapest & probably best way is to pull the head, cylinder, crank etc. & take them to your local machine shop. They will be the one that has to machine any pieces & will have the best knowlege to help you decide what has to be replaced or re-machined. If you don't know of a good tractor machine shop in your area just ask your local tractor club (any denomination)& they will point you to the best in your area.
Bill Oakes
03-18-2001 17:54:42
 Re: Re: What tools do I need? in reply to clooney, 03-18-2001 17:20:06
Thanks for the advice Clooney. I was thinking I should have my own measuring intruments because every book I read talks about measuring things like bores, diameters, backlash, end play, etc. Even the JD manual has many precision measurements to determine if a parts are within tolerance. Seems like many things would have to go to the machine shop to get measured. Just thinking out loud. Thanks again, Bill
RonMC
03-18-2001 23:09:46
 Re: Re: Re: What tools do I need? in reply to Bill Oakes, 03-18-2001 17:54:42
Bill, I'd suggest a decent (not necessarily expensive)dial guage with a magnetic base - you can do a lot with one of these including thickness measurements, and a good set of feeler gauges. Add a vernier caliper and you have the means to do most of the required stuff. Some of the gauges for bore/taper/out-of-round, run to quite a few bucks for a somewhat limited usefulness. I'm a mechanic, so of course have to have all these on hand, but you shouldn't have to spend all that much for the items I mentioned - also you don't have to be a rocket scientist to learn how to use them. Hope this helps, Ron
