720 Backfires
Don
03-18-2001 06:40:23
I have 720LP that is backfiring bad when going
down a hill. It starts easy and runs OK under a
load(although I don't think it has the power it
should have and uses more fuel)I does not backfire
under a load. My first thought was timing. The book says 20 deg BTDC at fast idle, it was running
about 3 deg BTDC, I adjusted to 20 but it backfired bad at fast idle, moved back to 15 deg BTDC and it seemed to run better. Did a little better under a load at 15,but still backfired.
I install new plugs and electronic ignition last
fall. Is there anything else I should check?
thanks
Don
Spokerd1
03-18-2001 18:46:26
 Re: 720 Backfires in reply to Don, 03-18-2001 06:40:23
Don, If you set the timing as the book said and it was worse on the backfiring. Then that should indicate the distributor is worn or has a lot of slack. Check it out real close. Did you replace the whole distributor when you put electronic ignition on the tractor? I would have said the condenser was bad but you said you had electronic ignition. The problem sounds to be in the ignition system
Don
03-19-2001 18:57:31
 Re: Re: 720 Backfires in reply to Spokerd1, 03-18-2001 18:46:26
There does seem to be wear in the distributor,
I can move it back and forth a little bit. I also noticed that
with the timing light on the timing would change
about once every tenth time(it would show about
5 degrees difference 1 out of 10 flashes)
I wonder if the distibutor drive gear is worn
or could cam bearing be worn?
thanks don
Don
03-19-2001 18:56:30
thanks don
