2120 injection timing
mike
03-17-2001 13:23:31
What is the proper way of adjusting the injection pump timing on a JD 2120 with a Rosa Master(spelling?) pump, not the Bosch unit. Is there a plug/cover to remove on the pump?? OR do you need special equipment to do so? Thank you in advance - Mike.
Jim Nielsen
03-19-2001 02:52:59
 Re: 2120 injection timing in reply to mike, 03-17-2001 13:23:31
Its pretty simple:
1. Bring #1 cylinder to TDC on its compression stroke. - there is a removable cover that you can read the TDC mark on the flywheel through.
2. Remove the pump timing window, and then if the scribed lines do not line up, loosen the pump cap screws and turn the pump body till they align.
3. Retighten cap screws & then reinstall pump timing window.
david val
03-17-2001 20:55:41
when #1 piston is at end of compression t.d.c.,the timing pin,or a 5/16 long bolt shold be inserted in the timing hole in the flywheel housing and enter the cavity in the flywheel.
at that position, after removing the small cover on the injection pump, the tow scribe marks shold align.
