Gas Tank Fitting
John in OH
03-16-2001 19:46:08
The bronze fitting on the bottom of my 1937 B's gas tank is cracked fully through the thread wall. I tried to solder it but it again cracks as soon as I tighten the sediment bulb nipple into these tapered threads. Any suggestions on how this fitting can be repaired or is replacement the only practical solution? If it must be replaced, any suggestions as to locating a replacement? The flanged portion of this fitting is soldered to the bottom of the tank but it also appears to be riveted to the tank bottom as well. For what seems as if it should be a simple repair, it has me in a quandry!
burns
03-17-2001 17:04:34
 Re: Gas Tank Fitting in reply to John in OH, 03-16-2001 19:46:08
This isn't something that I practice but I have heard of others using the universal "JB Weld" to stop the leak.
I use a product that is used on aircraft tanks. It is a two part mix that works extremely well. You might check with a local airport. I enjoy a family member working for a major airline.
