Overhauling my JD 60 engine
Ben.So.Tex
03-16-2001 17:49:48
My 60 has been sick since I got it 8 mo ago. So it is time to fix her up. When I took the head off two of the nuts were smaller than the others? But the studs are all the same size. Is this normal? Do these two nuts go on the bottom of the head by the water outlet? One was on the side and the other was in the middle of the head. Now on the crank inserts 3 of the bolts have lock nuts with cotter pins. The other one did not have a cotter pin in it, and the bolt did not have a hole for a cotter pin, Do I need to fine a bolt with a cotter pin hole, or is the locknut OK? All 4 nuts were locknuts. This tractor has two fuel tanks so I guess it is a all fuel, are the rings and valves the same as gas? thank BEN.
G Taylor
03-16-2001 20:34:58
 Re: Overhauling my JD 60 engine in reply to Ben.So.Tex, 03-16-2001 17:49:48
In the long run the job will cost less with the operator,service,electrical & part manuals in hand. Avalable from this site & from Deere at 1-800-522-7448. The 620 manual may get substituted for the 60 book but it's close enough. Measure the bore with a new ring & feeler gauge. It'likely egg shapped. The oil bath aircleaner is sure to be plugged with dried oil/mud, get it boiled out. Late A's & 60 would blow head gaskets if over heated or worked hard when cold. Mill only enough metal of the head & block to square them up. Use a medium stone to leave rough surface to grip the gasket.Purchase all new studs,nuts & hardened washers of proper strength. The old studs/nuts are done for after being under stress for nearly 50 years. High altitude or LP pistons will perk it up & run fine on pump gas. The cam has likely had the lifters switched around.Can't always see the damage with the naked eye. Get them all reground if you want the engine to run right. New valve guides are must as well. A cold manifold if being worked or pulled, a heated manifold if for parades & show duty. Enjoy, the 60 is a good old tractor.
Dan
03-16-2001 18:37:46
As I recall the nuts on tose stud bolts are larger outside thannormal, probably someone took it apart before and lost or ruined 2 of the nuts. I'd try to get the originals if I were you as they are larger and so go farther beyond the
hole in the head. the bolt on the inserts, I assume you mean the rods, should both have the hole for cotter pins. again the original is probably under some shade tree somewhere. I would try to get the right bolt so sometime when you have it it doesn't come out or loose and cause ya some problems.
