High Altitude pistons and a JD AR
Matt Timerman
03-15-2001 20:03:50
Would using high altitude pistons boost the compresion ratio and thus the horsepower of my JD AR? I wouldn't have any troble using regular octane fuel would I?
G Taylor
03-15-2001 20:20:56
 Re: High Altitude pistons and a JD AR in reply to Matt Timerman, 03-15-2001 20:03:50
Yes, power & efficiency will be improved. Detonation can be caused by many factors. Timing, spark scatter from worn components, incadescent combustion chamber components, overheating, oil consumption, bootleg low octane gas . Don't forget to completely disasemble the oilbath aircleaner. It's certain to be 1/2 plugged with oily mud. New valve guides & seals are a cheap way to increase valve/seat life & reduce oil consumption. All Fuel Valves have larger heads but sometimes longer stems. They can be shortened & installed with larger seats. May as well get a pulling cam if in this far. For all the hours it will be operated the extra cost of premium fuel will be neglegable with less fuel per HP. May even use the 60 LP pistons if your AR is a late unit.
