JD #9 cutter
Zoll
03-15-2001 17:51:59
I just found a #9 and would like to restore it
What should i pay for it.the gearbox works just needs a little shine. Thanks Zoll
Dan
03-15-2001 20:12:18
 Re: JD #9 cutter in reply to Zoll, 03-15-2001 17:51:59
Not sure about price. Know they were a good mower and a lot still in use for cleanup and so on out here anyway. Since they would fit on a standard 3 point a lot of guys used them on other makes of tractors. good luck on the fixup project
I have a number 8W mower which was similar except it has a wheel, in fact the parts book I have covers #8, 9, 8W and 9w. The W ones were set up so row croppers didn't ahve to move the tires in to use them.
grm
03-16-2001 15:50:31
 Re: Re: JD #9 cutter in reply to Dan, 03-15-2001 20:12:18
I just bought a 9W and paid $275. It had been stored inside and looked good. After I started servicing it I realized there was no oil in the gear box and everything was pretty rusty inside. I'm replacing all the bearings. That cost me $70 from a bearing dealer. I would not have paid that much if I had known what it looked like inside. Sickle bar mowers are getting hard to find around here and I looked quite a while before I found this one. Most everyone uses a disc mower these days including me. I'm going to use the 9W to cut ditches.
Roger
06-07-2002 20:21:46
 Re: Re: Re: JD #9 cutter in reply to grm, 03-16-2001 15:50:31
I have a #9 mower and was wondering if you might have a picture of one. Mine has some parts missing where the bar picks up .Can't figure it out
