420 tom check valve ques
Henry J
11-19-2003 10:24:54
Well things went better this am when the sun burned off the frost.
I am still scratching my head on the check valve issue. The book says to check and lap surfaces if they need it. I have the single stage check valves. Is the surface they are talking about the large end of the valve assembly where it mates in the housing?
Also one of the check valve push rods show where is has done a lot of rubbing on something, I presume the control valve rod that runs through the housing at a 90 degree angle where the check valve sticks in. The other check valve rod end shows no evidence of ever touching anything inside the valve housing. Something don't seem right here. This brings up the issue of the shims in the check valve. Maybe I need to read some more, but havn't run across the place that tells about shimming.
My tom had the jinking up and down motion that the book referrs to as being caused by leaking check valves.
Someone have the answer, I would appreciate it.
tom
11-19-2003 13:14:17
 Re: 420 tom check valve ques in reply to Henry J, 11-19-2003 10:24:54
Henry,
Wayne pretty much summed it up for you and has done six TOM overhauls...
I am assuming that your 420 has a dual TOM...usually the left control arm/knob operates the single inner lift arm, and the right control arm/knob controls the two outer lift arms...either way, the check-valve that is worn [and respective control-valve], do these correspond to the side of the lift arm(s) that are slipping? Did you try the other lift arm to see if it is slipping or not?
My point is that if the slipping occurs with the side of the worn parts, then you could move the less worn check-valve/pushrod and respective control valve to the side of the housing that controls lifting the two outside lift arms, that is if you can not find suitable replacements or the $$$$ are too high, or do not have the need to operate the inner/single lift arm...all the other parts you could leave the same...If you did move the "good" or working check-valve/push rod to the other side,I would at a minumum try re-seating the check valve in the new bore, and the control valve if you need to do so...
Maybe Wayne or someone else could comment on this to determine its viability...I have no idea how much new or used check valves & push rods, control valves, etc cost, but if you have to get different ones, then there is no difference in introducing your good check valve/push-rods into worn side than ordering new/other ones and installing them.
The real question is by trying to fix the slipping side and using the parts to the good side [if it was working and was tested], will this possibly leave you with two sides that do not work properly. This can only be done with more testing time and work...comes down to the ultimate question for us all: Time vs Money.
Keep us posted and good luck,
tom
Wayne in Tn.
11-19-2003 11:04:09
Henry J. Yes, on the check valves, refering to where they seat in the housing...just put some valve grinding compound on the end of the check valve, then slip it back in the housing, then take a screwdriver and lap it back and forth between your palms. Make sure to clean all the compound out when finished. Also keep up with which valve went into which hole. You can get a small tube of the compound at any auto parts store. The one you mentioned showing some wear,,,look on the control valve rod for a groove worn in it. You may need to find a better check valve, if yours is worn bad. Also if the control valve has a deep groove, you may need to replace it too, possibly with a better used one. As to the shims, try to keep up with how many was in each one and put them back that way. These more or less, control the speed of the opening and closing of the check valve. As to the lift jumping up and down, I would stretch those springs on the c-valves, a little, to make them seat a little harder.
Henry J (Thanx Wayne-nt)
11-19-2003 12:57:54
 Re: Re: 420 tom check valve ques in reply to Wayne in Tn., 11-19-2003 11:04:09
nt
