60 crank seal?
Toby
03-13-2001 16:42:27
Friend of mine has a JD 60, year unknown. Says when parked on a slope with clutch housing facing down clutch gets oil soaked. I have never done any
major work on 2 cyl Deeres, Is this a major undertaking? He asked me to work on it for him and
after hauling 2 tractors and some implements for
me and refusing to take money or fuel I feel it is the least I can do. Any help and advice will be
greatly appreciated.
Thank You,
Toby
clooney
03-13-2001 17:41:16
 Re: 60 crank seal? in reply to Toby, 03-13-2001 16:42:27
Toby, it sounds like either the pulley bearing seal is worn, or the oil drain holes in the pulley hub are plugged or the first reduction cover to crankcase drain hole is plugged. If you pull it apart you should be able to see where the oil has been leaking. Make sure you mark the clutch driver to crank before removing the clutch driver & get the big center attaching bolt tight when reinstalling the driver as those drivers have a habbit of working loose & tearing up the crank.
Toby
03-14-2001 17:24:48
 Re: Re: 60 crank seal? in reply to clooney, 03-13-2001 17:41:16
Thanks for the help clooney,much apppreciated.
Toby
