3020D, PTO coming on, when in 2nd through 8th gears,at about 1600RPM
Pete Reinke
03-12-2001 16:58:49
I have a John Deere model 3020D with powershift.The problem is when you are in 2nd through the 8th gear the pto engages,at around 1600 RPM automatically,without engaging the pto lever.With the tractor in park and the engine at 1600-2400 RPM, the PTO DOES NOT engage.The one thing I checked was hydralic pressure on the pto control valve on the left side of the tractor.I had 0 PSI on the pto side when I tested it in park & in 2nd through 8th gears.I do not have A port to check pressure on the brake side on my model.Did anyone else have A problem like this?
RON
03-12-2001 17:13:48
 Re: 3020D, PTO coming on, when in 2nd through 8th gears,at about 1600RPM in reply to Pete Reinke, 03-12-2001 16:58:49
YOU HAVE LEAKING STEEL SEAL RINGS IN THE C1,C2 AND PTO CLUTCH ASSEMBLY THIS TRACTOR SOUNDS LIKE AN OLDER ONE WHERE YOU DON'T HAVE THAT TEST PORT.
J.D. HAD PROBLEMS WITH THIS AND CHANGED SOME OF THE PARTS IN THE FRONT CLUTCH ASSEMBLY TO GET A BETTER SEAL BETWEEN C2 AND THE PTO. GOOD LUCK
RON
03-12-2001 17:12:56
