John Deere G Live Hydraulics Question????
Gman
03-12-2001 14:52:45
I installed a govenor driven hydraulic pump and sometimes it will work and sometimes it want. When I installed the pump I removed the idler gear in the pto shaft pump,now I left the gear on the pto shaft. I have found when the pump want work turn the pto shaft on and I got hydraulics again,the suction for the live hydraulic pump comes right out of the pto pump chamber,should I have removed the gear on pto shaft when I removed the idler? I should have live hydraulics without the pto shaft turning. would like to hear some comments I've been greasy to long need some input. Later Gman
clooney
03-12-2001 15:57:19
 Re: John Deere G Live Hydraulics Question???? in reply to Gman, 03-12-2001 14:52:45
Gman, have you installed the A 4769R spacer plate between the power-trol housing & tractor (it blocks the square port between the old pump & the power-trol? The A 4769R plate goes between two gaskets installed between the power-trol housing & tractor. I wouldn't think leaving the drive gear on the shaft would hurt anything but I have always removed both gears when installing the "live" pump. It is possible the new live pump is worn & the old drive gear is helping prime it by pushing some (very little) oil towards the pick up. If you didn't install the block off plate or make a new gasket with a metal piece blocking the square port my money is on that being the problem.
Gman
03-13-2001 18:53:10
 Re: Re: John Deere G Live Hydraulics Question???? in reply to clooney, 03-12-2001 15:57:19
Clooney I have the spacer plate and gaskets in the proper places,and idler gear removed. I was mowing with a No.38 mower two hyd. lines and worked fine then for some reason it quit.I was trying to get the side ports to work,but i gave up on that for a while and connected the two hoses to the ports coming out of powertrol mower works fine without pto running,then when I hook up the plows with one hose (bottom) I have to turn Pto on to lift plows.A buddy told me when running with just one hyd. hose configuration I need to put the plug back in the top port? also he said to make sure the rockshaft is in the full lower position,haven't tried this yet.If you come up with something give me a shout.I'd like to thank you for posting back,running aaccross someone who even knows what a powertrol is a rarity much less troubleshoot a remote hyd.pump setup so thanks a bunch Gman
Craig
03-16-2001 17:54:01
 Re: Re: Re: John Deere G Live Hydraulics Question???? in reply to Gman, 03-13-2001 18:53:10
What are you powering with the Power-Trol? A remote cylinder to lift the cutter bar on the mower? Or is yours cable lift off of the rock shaft?
