720 with a broke gear
Russ
11-18-2003 18:36:05
My 720 had a clunck sound .6th and 4th.when I tore into the transmission I discoverd a broke 4th and 6th slinding pinion.How hard is this to fix.Would this be ok to run as long as I do not use these gears.thanks for your imput. Russ
Mike M
11-19-2003 06:52:38
 Re: 720 with a broke gear in reply to Russ, 11-18-2003 18:36:05
If your going to keep the tractor it might be worth your while to look closer for other problems
like loose locknut on lower countershaft and bad bearings and too much end play since your in there
its not that much more work. If your selling it you might just want to put on the blinders and not look closer. But this is not what I would recommend.
Clooney
11-18-2003 18:52:05
Russ, that isn't too bad a job.. The sliding gear shaft will have to be pulled out the L/H side far enough to get the gear out.. I can't remember ever doing it on a 720 but on others I have been able to work one of those center gears out past the shift rails without disturbing the shifter adjustment..[That will save you a lot of work if you can manage that]..
~On using it?.... That depends on the extent of the damage & what part of the gear is broken.. If the gear won't come apart & put gear pieces all over the trans it will probably still work.. If there is ANY chance that gear will self destruct then it isn't worth the EXPENSIVE risk..
[email protected]
R uss
11-18-2003 19:00:08
 Re: Re: 720 with a broke gear in reply to Clooney , 11-18-2003 18:52:05
Thanks Clooney There is one tooth broke off.I think your right .I will replace it .It dosent sound that bad.THANKS RUSS
