JD 3130 More newbie questions
HB
11-18-2003 17:09:13
1st, I want to thank everyone for their help with my new toy. Got some time to play with it today. Man after my 8N this one 'big sucker'. Hope you guys are right about 'bigger is better'!It has a 148 loader. The loader works good, but the control handles are really loose. Do you know if they can be upgraded to a joy stick? I understand the 3130 is from Canada. I ordered the maintenance book. $104.00. How can I find the SN number without removing the loader frame?
Which USA tractor is the same?
Thanks
leon
11-19-2003 04:28:46
 Re: JD 3130 More newbie questions in reply to HB, 11-18-2003 17:09:13
I wonder, if knowing the engine serial number which is easily visible on the tag on the side of the engine, a dealer could cross reference that to the tractor serial number for you. This would, of course, assume that the engine has not been changed. The engine is made in Saran, France and the tractor in Mannheim, Germany.
doug@upr
11-18-2003 19:04:39
unless you know of the previous owner that may have the sn wrote down some wear you'll have to remove the frame, i have seen numbers wrote on the front of the axle or front support, usually they match the sn on the tag. i am from canada, and yes it is a very common tractor up here, i believe that it is the same as a 2840 in the usa and the 2130 same as 2640.
joysticks are a nice option since they free up your connections at the back of the tractor, though they tend to wear out quicker than the factory hydr., but unless your planning on using them everyday 8 hr. straight, they'll last you a long time
