JD 214 Not turning over
Chris
03-07-2001 06:33:26
Got this tractor used and it will not turn over or even hum or click. New battery had no affect. Checked ignition switch best I could and found nothing yet. Help.
Johnny
03-07-2001 08:15:35
 Re: JD 214 Not turning over in reply to Chris, 03-07-2001 06:33:26
Chris.
Check and see if the safety switches are working. You should have one under the seat and also one that is hooked to the clutch. If these switches are unhooked or rusted they may not be working. If they are not working the tractor will not do anything. When you find the switches you can bypass them with a jumper wire just be sure and fix the switches because the tractor will start in gear if they are jumped. Aslo check and make sure that both ground wires are attached. On my 214 the cround cable has two pigtails. One has to be attached the the frame and the other to the engine. I hope I have helped good luck Johnny.
Johnny
03-07-2001 13:14:58
 Re: Re: JD 214 Not turning over in reply to Johnny, 03-07-2001 08:15:35
Chris I went to the john deere dealer and had him to pull the 214 up on his JD Vision and print me a copy of the wiring. If I can be any help just let me know Johnn.
Chris
03-07-2001 20:45:20
 Re: Re: Re: JD 214 Not turning over in reply to Johnny, 03-07-2001 13:14:58
YEEEEE E HAAAAA AHHHHH!
I found another safety switch next to the gear shift that makes sure your in Neutral. The switch was not quit closing right so after a quick adjustment (and tightning my batery cables) she fired up! Not bad for a $495 214. It's miller time.
Joe
03-08-2001 19:29:13
 Re: Re: Re: Re: JD 214 Not turning over in reply to Chris, 03-07-2001 20:45:20
does anyone know where to buy used mowing decks for the 214. I need one bad and can't afford $700.00 for a new one.
chris
03-07-2001 11:42:48
Thanks, for the info. I thought it might be something like safty switches. I'll check those tonight. Do you, by chance, have a wiring diagram for the 214? I'd really like to get one! Let me know if you know where one is.
Thanks again,
Chris
