J.D. 1947 B (PTO Lever Not Working)
Obie
03-06-2001 04:50:26
My friend has a J.D.B with electric start and he has a problem with the PTO lever its loose and not releasing the PTO which is engauged all the time.Is there a easy way to fix this PTO lever? And what should he look for? He wants to know if that top plate comes off of the transmission to get at it? Is there a fork on the PTO lever that hooks into something? Thanks Obie
nigelB
03-06-2001 15:39:48
 Re: J.D. 1947 B (PTO Lever Not Working) in reply to Obie, 03-06-2001 04:50:26
if its the same as a "A" obie which i think it is ?there nearly all the same prinibal , you have a few chouses there is a key that holds a shaft shifter arm to the leaver shaft could be broke (long shot), or more likely there is a lug on the end of the shifter arm that locates in a gate on a minnie slideing fork simalure to a gear change selector that could have broke off? or the side of the gate? you can take off the gearbox cover and inspect its a bit of a job to see and you may nead to drain the oil? best of luck to your friend its one a major job to do enything down that low , lucky for me iv just changed mine but i had a empty case to start with regards nigelB
