3 Valve Hydraulics
Larry White
03-05-2001 12:06:33
Can someone tell me what 3 valve hydraulics means? I often see it in ads for used tractors. I have seen tractors with 3 hydraulic remote outlets and two remote control levers. I assumed one controlled dual action cylinders and the other controlled single action cylinders.
JD70Jim
03-05-2001 15:39:27
 Re: 3 Valve Hydraulics in reply to Larry White, 03-05-2001 12:06:33
Larry: Beginning with the 20 series tractors (520-820) a new hydraulic system called "CUSTOM HYDRAULIC POWERTROL" was made available. It features a heavier rockshaft (controls 3 point) and an improved control valve system for operating either one or two double acting remote cylinders. This system was the currant state of the art hydraulic system. New generation Deeres could also be ordered with one or two outlets as well. Modern equipment can operate as many as 5.
Some other brands , AC and Case come to mind, were equiped on some tractors to operate only single acting cylinders. I hope this helps.
