Crankshaft Oil seal - LH main bearing at flywheel
JC
11-18-2003 12:29:56
RE: Proper installation of the cork seal that slips inside the "Flywheel spacer"
Do you soap it in oil, lightly grease it, install it dry? What do you recommend?
Thanks,
JC
Mike M
11-19-2003 07:17:10
 Re: Crankshaft Oil seal - LH main bearing at flyw in reply to JC, 11-18-2003 12:29:56
I have at times smeared the cork with silicone sealer installed it and set the end play before it sets. I use this because the sealer is slipery
and once in place sets up and seals it to the crank. I also do this on those large o-rings that seal the cooling pipes and the slinger packings on the later models.
John T
11-18-2003 12:57:21
JC, my own personal opinion is to soak it in oil, and I have even had it in a small pan of oil near the top of the shop stove so she gets a good warm soaking. Seemed to work fine for me at least, and get the flywheel back in to the proper clearance (around 0.010 I believe, I always forget) and the oil slinger in place. John T
Bguy
11-18-2003 12:38:01
I like to soak it in a little oil to make it more pliable. Make sure there are no burrs or anything for it to snag on or cut it as you slide it down the shaft.
