3020 tach not working
JOHN
03-02-2001 18:26:17
I have a 64 3020 gas the tach some times works fine at start up but after a few minutes or a few more rpm the needle burries out to 2500 rpm and them bounces all over. Is the tach shot or some thing that can be fixed?? I would think the cable is ok since it dosent just stop working. any ideas or places to send my tach to. how about cost to fix. thanks
Dry spot in cable
03-03-2001 06:26:19
 Re: 3020 tach not working in reply to JOHN, 03-02-2001 18:26:17
Lube the tach cable from both ends with JD chain and cable lube. While you have it apart check the cable for damage.
Lloyd
03-03-2001 06:46:42
 Re: Re: 3020 tach not working in reply to Dry spot in cable, 03-03-2001 06:26:19
I had a slight kink in the cable on my 4010 and it made the tach jump arround sometimes. Another problem I have had is that the end of the cable got loose so that the end would turn without the rest of the cable turning. that was also intermittent.
