JD4100 How is it?
Ron Wood
03-02-2001 14:12:16
I am considering purchasing a John Deere 4100. Are John Deere Tractors as great as their reputation? Is the 4100 better then the 455?
Any input is appreciated.
Jonathan
03-03-2001 23:40:49
 Re: JD4100 How is it? in reply to Ron Wood, 03-02-2001 14:12:16
I've a 4100 for 2 years, and love it. It's more like a small farm tractor. The 455 is more like a big lawn tractor. The 455 is probably better if you are only going to cut grass. But if you want to landscape, or move dirt, the 455 can't keep up. The 455 uses expensive Cat 0 implements, while the 4100 uses standard Cat 1. I run a post hole digger, flail mower/shredder, box scraper, middle buster and much more off the back of my 4100. The 455 is too light to handle most of these. The 455 loader doesn't have the lifting capacity of the 4100 loader. The HP alone isn't the key. But don't limit yourself to Green if you're looking for a compact or sub-compact tractor. Consider Blue and Orange too. All good quality. If you decide on a 4100, you'll be amazed at what it can do. It's a great machine. Best of luck.
