2020 threepoint lift problems
John Guest
03-02-2001 06:59:11
My three point lift will not lift all of a sudden,the steering and brakes work fine (hydraulically).I changed the large filter rh side of backend ,no help. Any ideas where to look? Thanks in advance for any help,John in Memphis
david val
03-02-2001 23:04:08
 Re: 2020 threepoint lift problems in reply to John Guest, 03-02-2001 06:59:11
some 2020s had a separate steering pump, brakes do not operate on hyd.pump's pressure.
more data is needed about your tractor.
if you have the closed center system like the 2030, and steering is ok, then something probaly broke in the rockshaft oparating linkage.
david
