Robert, do you remember what bearing and seal
Add-on waterpum
11-18-2003 09:10:48
you used to repair the waterpump? I need to repair mine. I installed a new radiator on my "51 A that has smaller tubes and the old gal will not stay cool now with this new radiator.
Robert
11-19-2003 05:51:24
 Re: Robert, do you remember what bearing and seal in reply to Add-on waterpump, 11-18-2003 09:10:48
I'll have to look in my "archives", but I got the new bearing from the John Deere dealer, and it came with the seal. It was not an exact match, because the shaft on the new bearing (you get shaft and bearing as an assembly) was a bit shorter than the original, so the shaft doesn't quite come all the way through the pulley, but enough to secure the pulley.
Mine was originally leaking around the "nose" of the pump, and the inside of the pump was pitted pretty bad, so the new seal didn't have much chance.
We're probably talking about two different "animals" though---my pump was an aftermarket for my '45 A, which didn't come with a pump. I think yours, being a '51, had the pump as part of the lower tank. I don't know if any of this pertains to your application---good luck, though.
