J.D.B Leaking Water
Obie
02-27-2001 05:07:16
We have a 1946 J.D.B with cast frame and water is dripping from under the block cannot see leak cause of the frame..Dripping VERY slowly,,Is there any easy way of finding the leak without ripping the tractor apart? There is no water in the oil..
Thanks
Obie
Roy
02-27-2001 18:23:21
 Re: J.D.B Leaking Water in reply to Obie, 02-27-2001 05:07:16
Have seen blocks to be rusted thru, hope thats not the case. If it was drained every winter instead of antifreeze it could be your problem. Try to clean it as best you can, and maybe presurize your system to make it leak faster and see it easier.
Bill Oakes
02-27-2001 05:45:32
Obie,
The lower water pipe from the radiator bolts to the bottom front of the head. That would be the first place I would look. An easy fix if it's a bad gasket; a little more work if it's leaking through a rusted pipe. Bill
JDFREAK
02-28-2001 15:37:23
 Re: Re: J.D.B Leaking Water in reply to Bill Oakes, 02-27-2001 05:45:32
I tend to agree with Bill, if the gasket around the lower pipe going into the bottom of the head is leaking, it could be running back on the block, puddling and dripping there.
OR
You might keep a very close eye on the bolts which attach the block to the main case. I've seen water leakage there too. This would be indicative of internal block cracks.
If your tractor has a water pump, get some radiator sealer and go to it. I even used Pepper once, it lasted a few months.
Look real hard and inspect carefully for the source.
JDF
