JD3020 oil usage
Randy
02-26-2001 15:45:06
hello all
I have a JD 3020 that uses about 1 qt of oil to 15 gals gas.Mostly use this tractor to run log splitter. compression is 145-150(spec is 160) smokes like crazy at times and fouls plugs.valve guides tight(no slop) and motor was rebuilt about 800hrs ago but back in 1977.yes it has sat awhile
dont blow oil out the vent tube so i think the rings should be fine. am i missing something else
that i should be looking for or did this thing just sit too long. any help would be welcome
thanks in advance
Randy
twopop
02-26-2001 17:42:14
 Re: JD3020 oil usage in reply to Randy, 02-26-2001 15:45:06
check the ventilator pump on the left front of engine,pull the tube that runs from the pump to the intake manifold and look for oil residue.the pump can send oil into the intake manifold
