John Deere 420 Crawler stuck?
Paul
02-26-2001 11:38:36
I have a John Deere 420 crawler, I was driving along and it just locked up. The engine runs fine with the clutch pushed in, if you try to let out the clutch with the transmission in neutral it just stalls the engine. I pulled the cover to the transmission but every thing looks good no broken gears or bearings. I also pulled the cover on the side so you can see the shaft that goes from the clutch to the transmission but I can�t see any thing wrong. Any help would be greatly appreciated. Thanks Paul.
Paul
02-28-2001 13:17:53
 Re: John Deere 420 Crawler stuck? in reply to Paul, 02-26-2001 11:38:36
I don't think that it is in the final drives because with the transmission in neutral it still stalls the engine so I an guess that it is in the transmission. I am also think it is not the final drives because I can pull it while the transmission is in neutral but when I put it in gear I no longer can be pulled.
Thanks for your thoughts Paul
Britt
02-27-2001 19:13:33
Paul,
You say that you were traveling forward & the tractor suddenly stopped and now the engine will stall when the clutch is let out while in neutral. It would seem to me that you must have a broken tooth or a locked up bearing. Possibly some foriegn item such as a bolt has found it's way into the input gear set, locking the transmission input shaft.
You could try this:
Take the spark plugs out and bar (turn) the engine over opposite to it's normal rotation. Do this with the clutch engaged and the transmission in neutral. The object is, if there is a foreign object locking the gears, turning the gears backward will cause it to fall out and free up the transmission. However, even if this frees the transmission, you most likely have damaged gear teeth. Even if the tractor operates, you need to at least remove the object that caused the problem. Usually when something like this happens, the affected gear teeth are cracked and will fail soon. It is a lot of work to tear down your transmission, but operating it now (assuming that it frees up), will probably destroy parts that are not yet affected. The fact that the engine will stall even when the transmission is in neutral definately points to the transmission as the culprit. Wish that I could give you better news. "E" mail me when you find the problem.
Good Luck,
Britt
Andy Mz
02-28-2001 08:19:49
 Re: Re: John Deere 420 Crawler stuck? in reply to Britt, 02-27-2001 19:13:33
Paul Can you isolate the trans by pulling the axles? This will allow you to determine if the engine trans is okay, then check to see which final is locked. Post this query at crawlers dozers on this site. We use this method on Cat 9 or 10s.
