Clutch Problems!
AWB
02-25-2001 17:10:48
I am restoring a John Deere LA. The Local clutch rebuilders inform me that they cannot get parts to rebuild my pressure plate. So, they ordered me a replacement aftermarket pressure plate that bolted to the flywheel perfectly..the only problem is that the new pressure plate has a hole in the center that will not permit the Clutch Throw-Out Bearing to go forward far enough to disengage the Pressure Plate from the Flywheel. My question is where do I go from here? Does anyone out there know of anyone who can rebuild this Pressure plate assembly? Thanks, AWB
David
02-27-2001 14:01:24
 Re: Clutch Problems! in reply to AWB, 02-25-2001 17:10:48
Lexington (KY) joint and clutch has worked miracles for me before. Give them a call 859-254-3362. I'm sure you could UPS yours in and them send it back, if you're too far away.
