A John Deere for pulling transmission
Shohn Busald
02-24-2001 18:33:51
I have heard several rumors about there are 3 different transmissions in an A. when were they put in and which is best for puiiling live and dead weight? Mine is a 1950 A john Deere.
Shorty Dear
02-25-2001 18:52:50
 Re: A John Deere for pulling transmission in reply to Shohn Busald, 02-24-2001 18:33:51
I have sold the first reduction gear and the pulley gear out of the later A's to guys who are slowing their earlier model A's down. They tell me it is like the same speed as the later A's with the creeper gears in them. I have 2 more sets for sale if anyone is interested.
DP
02-25-2001 06:39:27
As Green Envy said you are correct. The 1950 models came out with the single stick transmission, also the axle housing had been squared. On the model B's, the single stick transmission was introduced in 1947. Both models had creeper gears with the one shift lever transmission.
Green Envy
02-24-2001 21:40:31
When the "A" was first introduced, it had a 4 speed transmission with a HIGH and LOW in the 1st and 2nd gear. In 1941 they added a 3rd gear so that they had HIGH and LOW in 1st, 2nd, and 3rd providing 6 speeds. Somewhere in 1947-1950 range Deere got rid of the HIGH and LOW lever and provided just one lever for all 6 speeds
BOZO
02-25-2001 18:14:49
 Re: Re: A John Deere for pulling transmission in reply to Green Envy, 02-24-2001 21:40:31
Did't they use pretty much the same transmission and use a single lever to select 3 forward and one reverse and also kick the secondary between high and low range? An improvement J D might have made was to have had two reverses in the old two lever transmissions, the high range equal to that provided and a low range for backing wagons.
