JD317
Bill Bradley
02-23-2001 18:17:56
I'm trying to figure out how the air cleaner is supposed to be attached on a 317. I have the air cleaner, it has a hole in the center, but there is no tapped hole in the carb for an attaching bolt. There is a horizontal rod (or bar or tube) in the carb. can I make a "J" bolt, hook it to that and put a nut on top?
any help would be appreciated
Bill
Donny-B
02-25-2001 08:07:28
 Re: JD317 in reply to Bill Bradley, 02-23-2001 18:17:56
If your 317 has a Kohler 17 twin, the carb has a 90 degree adaptor on the front and the aircleaner base bolts to it. The aircleaner base has a 3" stud that the top shell is held on by. Hope this helps.
