JD 2010 front end swap
Lee (VA)
02-22-2001 05:50:40
Hello all, I'm new on this list and new to the JD world. My experience is with the "other" colors. I have a friend who's looking at buying a '61 2010 w/tricycle front end. That's not a real good thing here in the hills of Virgina. The owner has a junker/parts only '64 2010 "utility" version with a wide front end. Can anyone tell me if these front ends are a direct swap. Just looking at it it looks like they are but both are still attached so I can't see everything. Thanks for any information. Also the utility wide front end has 15" rims on it and 26" rims on the rear. The tricycle has 36" rims on the rear and 14" on the front. The owner says 18" rims w/7.50X18 tires on the wide front end will level out with the 36" rears. Any experience or opinions on that. It looks like it will leave the front a little low to me.
Tom in Mo.
02-22-2001 18:22:02
 Re: JD 2010 front end swap in reply to Lee (VA), 02-22-2001 05:50:40
Hello Lee, I don't believe this is easy. The power steering motor on the row crop is different from the utility, so not only do you change the axles but also the hydraulics. Note that there are possibly changes from a 1961 and a 1964. The 2010 was a work in progress. On my 2010 utility are 15 inch front rims and 36 inch cast rears. It rides flat. You may want to invest $75. in a service manual before buying anything else.
