Rebuild kit for fuel pump
Junkman
02-21-2001 23:20:55
Does anyone know if I can get a rebuild kit for the fuel pump on a 3010? I can get a new pump, but it doesn't have the glass sediment bowl and I would like to retain that feature if it is at all possible.
Thanks,
John
McC
02-22-2001 00:04:50
 Re: rebuild kit for fuel pump in reply to Junkman, 02-21-2001 23:20:55
You should be able to get a repair kit for that fuel pump from your Deere dealer. It might cost about what a pump costs. Let me know if you need more help.
Junkman
02-22-2001 07:29:50
 Re: Re: rebuild kit for fuel pump in reply to McC, 02-22-2001 00:04:50
The Deere dealer says the rebuild kit isn't available for that pump. Do you know of any aftermarket kits?
John
McC
02-24-2001 00:58:04
 Re: Re: Re: rebuild kit for fuel pump in reply to Junkman, 02-22-2001 07:29:50
Send me an E-mail to remind me and I'll check into it on Monday when I get to work. I thought you could still get kits for those, but I could be wrong. I'm assuming you are talking about the transfer pump since you mention glass sediment bowl. Thanks.
Mike Aylward
02-22-2001 09:34:35
John, Deere hasn't furnished diesel parts for several years. They will refer you to "your nearest Diesel repair center". These parts are readily available and some Deere dealers will stock them from the Diesel shops and have them on hand. Hope this helps. Mike
