What loader fits a JD 2440?
Allen
02-21-2001 08:24:33
I'm trying to decide which loader to install on my 1981 2440. It has 2-remotes on the rear of the tractor. Are these used for the loader? Also, I would like to have a loader that installs/un-installs fairly fast.
Any help ould be appreciated.
JD70Jim
02-22-2001 11:01:19
 Re: What loader fits a JD 2440? in reply to Allen, 02-21-2001 08:24:33
I have a 145 loader on a '76 JD2440. It uses a separate set of valve spools so you can use the dual hydraulics without dismounting the loader.
TB SCOTT
02-22-2001 12:50:02
 Re: Re: What loader fits a JD 2440? in reply to JD70Jim, 02-22-2001 11:01:19
I have a 146 on a 79 2640 and it works great. I have mine plumbed next to the hydraulic filter housing then hoses going up to the 2 spool valve thats mounted to the loader. only two hydraulic hoses to disconnect and 8 bolts and its off. see your local jd dealer and he will give you the special t fitting and another fitting to hook quick couplers to for the two hoses. good luck :-)
