JD 50 Clutch problem
GT
11-17-2003 23:11:36
I have a JD 50 that has a clutch problem. The clutch will engage ok and when I disengage the clutch the tractor will stop, but if I pull the clutch lever all the way back, it will re-engage the clutch and the tractor will start moving again. Where do I start? I have the manuals but I can't find out about this problem. Any help would be appreciated.
Clooney
11-18-2003 03:33:11
 Re: JD 50 Clutch problem in reply to GT, 11-17-2003 23:11:36
GT, your problem is easy to diagnose but might be a little more difficult to repair [if you have a late 50]..
~Lets start with the WHY?... What's happening is the pulley brake adjustment is allowing the clutch collar to over-travel & contact the pulley drive gear, that in turn moves the pulley gear [& pulley] enough to re-apply the outer clutch plates when you pull the hand lever back far enough..
~Now for the repair?... If you have an early 50 [under s/n 5029200] all you probably have to do is adjust the pulley brake up tighter. [with the clutch snapped out & the hand lever free you want the pulley brake to just lightly stop the pulley]..
~If you have the later 50 [after s/n 5029200] the repair isn't so easy.. You can TRY a simple pulley brake adjustment [sometimes that's all it takes] but you might have to go in & shim the pulley brake apply pin.. That isn't so easy.. To see if the apply pin needs shimming [late 50 only],, dis-engage the clutch, then move the pulley in & out on the crankshaft.. If the movement is over about 1/8"-3/16" [with a correctly adjusted clutch] you will need to pull the clutch front bearing [that�s the 4 bolt cover that the clutch fork shaft turns in] & add or remove apply pin shims until you get it close... Now the hard part, you can't see in there so it will be a trial & error method..
~I can't post pictures from where I'm at right now but if you need a picture of that 50 clutch break down just let me know. [problem is,, the parts picture doesn't show much detail on that apply pin shim area].. It might take a while to find your E-Mail in my in-box as I'm well over 100+ E-Mails behind right now but I will eventually get to it].. Or post your request here..
~If you have the manuals it should all be in there..
~One more thing to check� You might want to check the crankshaft end play� If that�s excessive [over .015�-.020�] that could be effecting your clutch operation by sliding your clutch pulley too far to the right.. To check.. pull the flywheel cover�s small center cover then stick a dial indicator on the flywheel with the indicator base on the flywheel cover.. Then snap the clutch in & out.. If the end play is correct it will be between .005� & .010�.. If it is too high [probably over .015�-.020� pull the flywheel cover & adjust it by moving the flywheel in a little..
[email protected]
GT
11-21-2003 22:09:04
 Re: Re: JD 50 Clutch problem in reply to Clooney , 11-18-2003 03:33:11
Thanks Clooney! That is a pretty in depth answer. Looks like I got a little work to do this winter. Thanks again for the info.
Steve - IN
11-18-2003 03:14:45
GT,
In your manuals, check the section on adjusting the pulley brake. When it's too loose, you'll re-engage the clutch by pulling the lever back all the way.
GT
11-21-2003 22:10:33
 Re: Re: JD 50 Clutch problem in reply to Steve - IN, 11-18-2003 03:14:45
Thanks Steve for the info. This is the best site for getting good info that I have seen.
