Stripped Threads????
AWB
02-20-2001 18:52:57
I have a casting which has four bolt holes with stripped threads in them. What is the fix for this type of problem? Going to the next size bolt is not an option in this case. Thanks, AWB
burns
02-20-2001 19:15:56
 Re: Stripped Threads???? in reply to AWB, 02-20-2001 18:52:57
Depending on the size (I'm not sure on the availability of the large diameters) you can drill a hole a little bigger and add a heli-coil. Basically you are adding just the treads to the hole. There is a very basic process to doing this and they are contained in the directions. This will allow you to maintain the standard size.
