John Deere Gator causing fire
Billie J. Smith
02-20-2001 17:08:12
We had a John Deere Gator that we thought was the best Christmas present ever for about three years. The week before Christmas this year the alarm went off in our pond house. When my husband investigated, he found the John Deere Gator engulfed in flames. Before the fire department could arrive the entire building and all contents were destroyed. The John Deere Company does not accept any responsibility, even though the gator was the only thing in flames when the fire started, and even after the fact acknowledged by the insurance investigator and John Deere's own representative that examimation of the site would "suggest that the initial force of the fire was, in fact, the gator." We would be interested to know how many other fires have possibly been attributed to John Deere Gators and also warn others about this dangerous situation. This gator had been driven a little, then parked. A short while later there was a fire that was very devastating. I understand many people keep their gator in the garage.
G Taylor
02-25-2001 10:04:47
 Re: John Deere Gator causing fire in reply to Billie J. Smith, 02-20-2001 17:08:12
We have six Gators outfitted as fire trucks & ambulance parked in the Nuclear Plant where I'm a volunteer Fireman. If the cooling fan has never been cleaned of normal dry trash acumulated around it & the rad, it could get hot. Damgaged wiring harness from modifications,service,mice etc could be a problem expecially if oversize fuses were installed. Your unit must have been a 6x4 but gas or diesel? Sorry for your loss but Deere can't control what happens to machinery after it leaves the dealer. For the few bucks it costs everything is insured to the hilt around here. Even installed wet sprikler heads in the house kitchen, laudry room,furnace room,heated shop areas & all exit routes. Wiried smoke & heat detectors into the monitored home alarm system as well. Deere got busted in court for a house fire in the late 60's caused by a women refueling a 110 garden tractor. The result was the free rubber boot installation program over battery terminals. This women took the fuel fill cap & metal level indicator & laid it across the battery terminals, WOOF. The judge was oviously out to lunch on that one.
TractorNut
02-24-2001 22:08:27
I have a Diesel Gator. I would be interested if it was a gas or diesel that caught on fire. I often park mine in the hay barn. Might have to rethink that... Could there have been trash in the cooling fan under the seat? I have had to take the grill off of my cooling fan and remove trash that accumulates there.
Billie J. Smith
02-25-2001 18:14:37
 Re: Re: John Deere Gator causing fire in reply to TractorNut, 02-24-2001 22:08:27
This was a 6X4 gas powered unit.
MikeH-Tx
02-21-2001 18:53:41
I would be very curious to hear if this is a general problem with these models. I doubt it.
To make a fire from a vehicle, you need something to get hot. That means, usually, some sort of ignition switch problem. After all, the electrics are all off normally. It has to fail to start a fire. If it does fail, gasoline is explosive in any vehicle. Easy to understand that.
I would just guess that you experienced a rare event. This is the forum to find out though. If there is a common problem, you will hear.
Sorry for your loss, regardless. Not easy to see your $6,000 machine catch fire and take your shed with it. Hope you were covered.
Billie J. Smith
02-24-2001 12:27:18
 Re: Re: John Deere Gator causing fire in reply to MikeH-Tx, 02-21-2001 18:53:41
Hi Mike, Thanks for the response. We are at a loss as to what happened to the John Deere Gator, except we know positively it was what started the fire. There is a motor that runs even after you turn the ignition off---I think they said it was some sort of cooling fan. The insurance investigator said it looked like the heat had spread from under the seat where this cooling fan was and took it in to their lab to try to check, but could not conclusively say it was faulty. Also, after the fire, we had a visit from an employee of a local company that had a fleet of six gators who had heard about our fire and that it had started with the John Deere Gator. He wanted to know what we'd heard from John Deere. He said they'd had fuel leaks with 2 of their gators and had their employees do the repairs, but this incident had him concerned also. We did not have enough coverage for the extent of loss we suffered as this was an "all-steel" building that shouldn't have burned. At least no one died in this fire. I hope it doesn't happen to anyone in the future, but I would like to have some answers as to what caused this. Thanks again for your response. Billie J. Smith
ff316
02-24-2001 19:49:00
 Re: Re: Re: John Deere Gator causing fire in reply to Billie J. Smith, 02-24-2001 12:27:18
I've never seen or heard of a gator catching on fire. Theres not a lot of them around here, but if one burnt I would know it - I'm a Firefighter. If I hear of any I'll post it.
