JD M-Mt
Lloyd
02-20-2001 16:13:13
I would like to know the differences between the M and the MT I know the T means Tricycle , but I have heard someone say they had or have an MT with a wide front axle.Are there any other differences as I am interested in buying an M with the wide front axle. Thanks.
Theman
02-21-2001 10:22:30
 Re: JD M-Mt in reply to Lloyd, 02-20-2001 16:13:13
According to Two-Cylinder magazine the T stood for Two-Row. The straight rear axles on the MT allow for various row spacings for different types of crops. While the tread width was somewhat adjustable on it, the M had a limited number of settings (I think it was four). RonMC is correct about the MT being available in three configurations. Engines between the M and MT are the same.
RonMC
02-20-2001 20:09:56
Lloyd - the MT came in 3 versions, single and double tricycle, and adjustable front, and was available with fixed or adjustable rears. The M came in adjustable and non adjustable fronts and the rears adjusted by rim position as stated below. HTH, Ron
Bus Driver
02-20-2001 17:11:01
The M had offset final drive housings similar to a Farmall A (don't shoot me please for saying the "F" word). In standard form, these housings were down for increased clearance. The M used 24" rear tires, but 26" was an option. The MT had straight axles on the rear and tires were 34". MT tread width is adjusted by moving the wheels in and out on the axle. The M adjusted rear width by unbolting the rim and moving it to another position on the wheel center disc. Not the complete story, but answers youir basic question.
