GP clutch removal
Bill
02-18-2001 19:36:00
Trying to remove the outer adjusting disk on a 1931 GP clutch. Cleaned up the ID of the pulley, removed the three nuts on the adjusting bolts but only able to pull the adjusting disk out a quarter inch or so. Is this the right procedure or what else should be done to get the disk out?
mike
02-19-2001 17:17:57
 Re: GP clutch removal in reply to Bill, 02-18-2001 19:36:00
you are on the right track bill there are 3 springs behind there and the adjusting bolts work the clutch leaver if it is real stuck you can clamp 3 vise grips on the fins and pry around the pulley with them and a pry bar if not get back to us will sujest something else
ET
02-19-2001 08:39:34
That should let it loose keep trying.
