How to know when to replace Pedestal Bearing 520 P
Tyler-MO
11-17-2003 19:45:30
Hi guys,
I've got the front frame off of the 520 right now and am in the process of sand blasting it and then paint. But, since my restoration is going to be a compelte one I am rebuilding the powersteering system including the pedestal. So thank goodness that I bought a burnt 530 for parts. My steering shaft is somewhat scored where it rides in the bushings...but the 530 is not. It was burnt but i think that it will be okay. The only thing that I won't reuse is the thrust bearing. My question is that the bearing from my 520 (which was not burnt) might be okay....but I can't really tell. The steering was great on it and the only problems were leaks. So i'm hoping that I can reuse the bearing on the 530 shaft and save myself $85 on a new bearing. So if anyone has advice on how to tell if the bearing needs replacement please share. Thanks
Tyler
F-I-T
11-17-2003 20:54:15
 Re: How to know when to replace Pedestal Bearing 5 in reply to Tyler-MO, 11-17-2003 19:45:30
Tyler:
If you clean that bearing really well, dry it, and slowly turn it back and forth in your hand and listen and feel, you'll know if it can be re-used. Remember, that bearing doesn't support a spinning shaft. The pedestal shaft is centered by the upper and lower bushings, so all the bearing does is take the thrust, and then only for about 80 degrees in each way. I'd think it would have to be in pretty bad shape or have rode out a lot of rough ground to be real bad.
BUT, they sell them new, and almost always have them in stock, so someone buys them. At 7,000 hours mine looked and felt like new, and it had hopped a lot of clods.
Just be sure you install it correctly. I've seen some installed upside down. It says "Thrust" or "Thrust Here" (I can't remember off hand). Just look that picture up in your book and it will be clear.
Frank
