John Deere 620
Patrick Moss
02-16-2001 10:25:27
I am taking apart the engine. My problem is that I cannot remove the engine head. It appears to be
loose except around one stud. If anyone has any
suggestions please send them.
norton
02-16-2001 17:11:20
 Re: John Deere 620 in reply to Patrick Moss, 02-16-2001 10:25:27
Moss looks like you have some good followups!!!
BJP
02-16-2001 12:35:51
My father and I did the same job a couple years ago. Look on the sides inside the frame rails, there is a stud hiding inside a square hole, could be you missed it. Good luck.
luckydog
02-16-2001 12:10:25
Patrick--MAKE SURE that you have all of you nuts off of the studs. If you say it is loose I asume that you do. Check to make sure that you have your lead washers removed from around the studs and the threads. The stud with the lead washer on it can put a lot of preasure in that hole. Sometimes the head gasket can be bound between the head and block and you might have to pry them a part. Be careful when prying that you don't damage your goods by doing this. You might have to remove one or more of the studs to remove the head out of the frame. luckydog
Haybaler
02-16-2001 12:38:02
 Re: Re: John Deere 620 in reply to luckydog, 02-16-2001 12:10:25
And watch your fingers, the head is HEAVY!!!!! !!
