'38 A spark plugs
iajake18
11-17-2003 17:18:20
What spark plugs would you folks recommend for a '38 A John Deere. My father started a restoration today on one that has been sitting for 18 years ( was still loose) and it has Champion W-14's in it but we are not big fans of Campion plugs. Thanks, Jeff
Clooney
11-18-2003 03:49:23
 Re: '38 A spark plugs in reply to iajake18, 11-17-2003 17:18:20
Jeff, that's an easy question.. Try different brands & use the ones that work the best FOR YOU..
~Some of my old iron does better with Champion�s & others like the Autolite's better. It depends on the usage & tractor..
~Problem is with some of those old hand start tractors like your �A� the extended tip plugs like the Autolite do seem to foul a little less in a running tractor but tend to fuel foul easier when starting & you flood it.
~In any case due to the new [emission friendly] harder to evaporate & harder to ignite gasoline you probably want to use a heat range or two higher than the book calls for�
~A little more useful [or useless] information� If you can find some BRAND NEW old original type spark plugs they do much better about not fuel fouling due to the tip porcelains being glazed� [most of the newer plugs aren�t]�
[email protected]
John T
11-17-2003 19:47:32
My own personal preference and the best luck I have is using Autolite 3077, the side wire electrode plugs, or the AC equivalent.
God Bless John T
Earl S.
11-17-2003 18:48:32
3076 Autolite if you are going to work it in the field. 3077 if parade or slow speed.Earl
