Clutch adjustments on 3010
Junkman
02-13-2001 17:25:31
The service manual says I need a special tool to adjust my clutch. I have the synchro-range transmission. the manual shows how to make your own template for the powershift but not the synchro-range. Can anyone tell me how to make one or do I have to buy one?
Thanks,
John
RayE
02-13-2001 17:59:25
 Re: Clutch adjustments on 3010 in reply to Junkman, 02-13-2001 17:25:31
I think i've got a pattern for one i made several
years ago.I borrowed one from JD,traced it on a
piece of tin and cut it out.I could probably
trace it on paper and send it to you if your
interested.
Junkman
02-15-2001 08:20:07
 Re: Re: Clutch adjustments on 3010 in reply to RayE, 02-13-2001 17:59:25
Ray, Thanks for your offer, but I found a friend of my dad's that had a template. I borrowed it and have the clutch adjusted now.
Thanks again,
John
Duke
02-13-2001 17:33:53
You do need the tool to set the clutch fingers at the same height otherwise the release bearings will not ride straight, the fingers will wear, and the bearings will have a short life. Try to borrow a tool or you can bring the clutch and flywheel to your dealer and they can adjust it for you, takes less that a hour.
