3010 Throwout bearings
Junkman
02-13-2001 17:21:34
I am putting a clutch in my 3010, but am having some difficulty getting the throwout bearings out. I have the clutch bearing out, but still have to get the PTO bearing out. If I did get it loose, I don't think it would come past the collar that the clutch bearing sits against. The service manual doesn't go into replacing these bearings or I am just missing it somewhere.
Thanks,
John
Duke
02-13-2001 17:37:03
 Re: 3010 Throwout bearings in reply to Junkman, 02-13-2001 17:21:34
It will slide off over the collar. It is slightly inteference fit. I usualy use a pinch bar ant the control lever to get the bearing off.
Junkman
02-14-2001 12:03:39
 Re: Re: 3010 Throwout bearings in reply to Duke, 02-13-2001 17:37:03
Duke, Can you clarify some more please? Do you take the fork loose or do you just pry the bearing out of the carrier? I am ready to put this thing back together but need this bearing done first.
Thanks,
John
Duke
02-14-2001 16:23:26
 Re: Re: Re: 3010 Throwout bearings in reply to Junkman, 02-14-2001 12:03:39
suffering brain cramp been awhile but as I remember just the release bearings come off the collar
Junkman
02-14-2001 23:59:41
 Re: Re: Re: Re: 3010 Throwout bearings in reply to Duke, 02-14-2001 16:23:26
thanks for all your help, I was able to get them changed. Tractor will go together on Thursday!
John
