3010 injector leak
david
02-13-2001 11:00:17
Working on a 3010, it came in with no compression leaks around injector. I replaced the injectors (and copper sealing washers) and now #1 cylinder is blowing compression around the injector (I have checked to make sure there are not double sealing washers. Any ideas?
david
02-14-2001 09:29:48
 Re: 3010 injector leak in reply to david, 02-13-2001 11:00:17
Thanks, that was it, one speck of carbon about 1 milimeter right in the bottem corner.
Spokerd1
02-13-2001 15:43:16
David, Check to see if you do not have a small piece of carbon which has fallen off of the injector when you pulled it. Sounds as if the injector is not seated properly in the head. Check the injector for a burr on the barrel. you might have nicked it when you pulled the injector.
Fudd
02-13-2001 21:06:37
 Re: Re: 3010 injector leak in reply to Spokerd1, 02-13-2001 15:43:16
I alays use a bottle type brush on our trucks when I take out the injectors. The sealing surface has to be clean and the washer can not have any nicks on it. Good luck.
