J-D 600 tractor motor
RonMC
02-12-2001 22:58:02
Hi Guys, I have an acquaintance up north who called me the other day to see if I could locate an engine or short block for his tractor/backhoe unit. I think it should be the 404 6 cyl diesel. Can't seem to find much info on this, and the local crawler salvage doesn't have anything, so was wondering if someone could tell me what other machines this engine might be found in ? Kinda like to help him, nice man who has a couple of A's as well and a real J-D fan. Thanks for any info, Ron
The Stranger
02-13-2001 05:38:29
 Re: J-D 600 tractor motor in reply to RonMC, 02-12-2001 22:58:02
A JD 600 is the industrial version of a 4020, and used a 404 (diesel) or 341/362 (gasoline) engine.
A number of Deere tractors used these engines,as did the 105/7700 combines. Shouldn't be any trouble to find one, or to rebuild what he has, as parts are plentiful and relatively cheap
McC
02-13-2001 01:17:43
Ron, I think the 600 was the industrial version of the 4020. You should be able to find an engine or a short block for one of them. They used that 404 engine in a lot of other things, but I don't know if they are an exact interchange or not. A JD industrial dealer may be able to help more. Hope this helps.
