JD 4430 FWA
KC from BC
11-17-2003 16:09:05
I'm interested in a 1975 JD 4430 with front wheel assist. Is there any pro's or con's about the FWA?
KC from BC
11-18-2003 16:50:29
 Re: JD 4430 FWA in reply to KC from BC, 11-17-2003 16:09:05
Thanks for your inputs, fellows.
ET
11-18-2003 06:50:10
The front wheel assist will cut down on wheel slip and increase fuel economy when plowing or working ground. A selling point for them was that they saved more fuel than a 2 wheel drive tractor with duels.
farmer
11-18-2003 03:03:06
The potential benefit does not out weigh the potential cost on this hydraulic driven front wheel drive.
david val
11-17-2003 22:25:18
the system utilises electo hydraulic valves. most of the problems are electrical and fairly easy to diagnose. rotary swiches in quad range and synchro range are pretty costy though, and so are the solenoids.
david
RJ-AZ
11-17-2003 19:34:08
Like G-man said it seems that those who like them really like them and those that don't don't. The HFWA stands for Hyraulic Front Wheel ASSIST and is not to be confused with Mechanical Front Wheel DRIVE. We operate the same system on our 672B and 772BH road graders and I do A lot of hydraulic hose replacement on them. And when they start leaking the price goes up real fast. But it does help on our machines during winter snow plowing with a front plow and side wing plow.
G-MAN
11-17-2003 16:18:18
I've been around very few HFWA tractors, but have heard good and bad. On the con side, they're certainly nowhere near as strong or efficient as a true MFWD system, and they're also not cheap to rebuild if there is a failure. You might also make sure your local dealer or whoever does your service work has some experience with them, in case you have problems. On the pro side, they DO add a little pulling power, and will help you get around better in mud or snow.
