Brass plugs in Carb
Deere Puller
02-12-2001 19:29:06
Whats the best way to get the brass plugs out of the carb without messing up the slots?
Mike Aylward
02-12-2001 19:35:41
 Re: Brass plugs in Carb in reply to Deere Puller, 02-12-2001 19:29:06
Deere Puller, the easiest and best way is to use a little heat on the plug ONLY. Just get them warm (not hot), let them cool and they usually will come right out like new ones. Hope this helps. Mike
rollo
02-13-2001 04:41:26
 Re: Re: Brass plugs in Carb in reply to Mike Aylward, 02-12-2001 19:35:41
Mike's right - and make sure the slot in your screwdriver fits the slot in the plug exactly. You don't get a second chance when you tear up the plug.....unless you drill it out and retap the hole...been there, done that...
