G clutch drive disc?
BigJ
02-12-2001 14:09:14
I just got my G(serial no.53891)home and noticed there is lots of play in my clutch drive disc splines.I have not had time to remove it to see how bad it is but is there an easy cure or does the crank and all have to come out?It sure does run good and I hate to tear it down if I can help it.Thanks Jack(TN).
clooney
02-12-2001 14:23:56
 Re: G clutch drive disc? in reply to BigJ, 02-12-2001 14:09:14
BigJ, tear it down & see what you have. If it is just loose & the crank is not all torn up or butchered by the previous owner there are undersized spline drive disks available from a couple of vendors.
How do I determine size?
02-12-2001 17:21:19
 Re: Re: G clutch drive disc? in reply to clooney, 02-12-2001 14:23:56
How do go about measuring to get the right undersized drive disc?I was looking through last months Green Magazine and Dengler had them in all different sizes.Thanks,Jack(TN).
rollo
02-13-2001 04:37:46
 Re: Re: Re: G clutch drive disc? in reply to How do I determine size?, 02-12-2001 17:21:19
I bought a replacement clutch disk from Denglers for my "A." You don't have a lot of choices. Call Dengler and talk to them about yours. They are in business to sell parts, but they seemed knowledgable and straight to me. Mine fit exactly, but they will tell you how to measure and make one fit yours. You gott'a want it, because they are fairly expensive, but I had no choice: I couldn't build up the splines with a welder (not good enough); and there is no new crankshaft available for an "A".
