H Implements
JC
02-11-2001 17:27:52
I have been interested in buying a JD H and I have found a couple within driving distance of my house. I have also found another fellow with cultivators and a mounted plow for the H (I have not investigated whether these implements came from an H with or without hydraulics, and I'm not sure the Seller knows anyway). Of the tractors I am looking at, one has a power lift and the other does not.
My question is, will the cultivators and the plow work on either H? Or is there a big difference between the implements made for tractors with power lift, versus those made for tractors without power lift?
Thanks in advance.
Mike Aylward
02-12-2001 05:56:25
 Re: H Implements in reply to JC, 02-11-2001 17:27:52
JC, the predominant difference between using the hydraulic cylinder for lifting or manual lifting will be that both the plow and the cultivator will have a long lift lever with two springs and a pivot toward the top, with a mounting bracket that mounts on the right hand axle housing. If neither implement has this, then they likely are set up for hydraulic lift. Hope this helps. Mike
