Dual Wheels
Steven Brown
10-14-2003 10:55:23
With the popularity of dual rear wheels on modern tractors, how popular were duals on, say, the letter series tractors, particularly the A's, B's, G's. I've seen a picture or two of a "G" with duals, but that's about it.
Charlie
10-20-2003 08:32:44
 Re: Dual Wheels in reply to Steven Brown, 10-14-2003 10:55:23
We have an original 39 G, meaning not repainted, we are 2nd owners, and it is on round spoke rears with factory dual equipment.
37D
10-16-2003 18:17:56
I had a "G" with a "power block"- needed the 15.5 tires & 13.6 duals to make it pull right. Used it with an "801" 3pt,& a 15 1/2 ft C10 field cultivator. With 500lbs of front weights it would run all day in 3rd gear. Had a neighbor who ran clamp on duals on a "pressed frame " "A". Can't imagine that he needed extra traction, but he put them on every year anyway!
Doc
10-15-2003 18:48:43
I've always wanted to put a set on my A, I have an older A with pressed steel, and thought it would look cool to turn the hubs inside out, and dish the wheels out mounting the pressed steels on the outside. Would stablize the loader tractor quite a bit I'm sure.
Hmmmm Maybe a G, with duals, and a new generation cab from a 4030...
Doc
easydoesit
10-15-2003 11:21:05
Steve, The Duals were offered as standard equipment for the unstyled G as the production book shows and quite a few people ordered them in Iowa and Nebraska. There was only one hub and mounting hardware tied the rims together and then to the hub. The hardware gets loose if you don't watch it and I'm sure that keeping four pneumatic tires up in the late 30's was alot of trouble. Many original dual hubs were welded to the inside of a single rim and are commonly still found that way.
Dan
10-14-2003 12:56:15
I have also seen some on older tractors, As and Gs here. Guys here put them on in the fall and/or spring to help with compaction. Even sod ground gets wet in spring and to get on it quicker and still not compact soil teh duels help. ON a lot of the big tractors the guys here use duels that go to the axles. Harder on old tractors as many of the axle's weren't that long. Think also there is more concern these days for compaction. I have run duels on my SMTA for discing but not on my G (don't have wheels that fit). Some guys here use "clamp on " duels also.
Dr.EVIL
10-14-2003 13:29:52
 Re: Re: Dual Wheels in reply to Dan, 10-14-2003 12:56:15
My Dad was one of the First Farmers in Our Neighborhood to run duals, direct axle mounts, back in about 1960 or '61, strangely enough also on a Super M-TA, then a 450, then fianlly after finding different hubs a 4010-D. At one time He had duals for EVERY tractor He ran, including the '51 M and '54 Super H Farmall. Some Farmers never did get duals.
F-I-T
10-14-2003 11:34:34
Steve:
We ran duals on our '70'D for many years. When we stopped moldboard plowing, we left them on year round. Really helped with traction and made it ride much better.
Our neighbor used them on his "G", too. We also had duals on our AC 66 back in the day.
Frank
